1994 6.5 turbo diesel,died won't start
Old Oct 18, 2013 | 12:37 PM
richardk's Avatar
Default 1994 6.5 turbo diesel,died won't start
have a 1994 chevy 6.5 turbo diesel , died at red light , towed home turns over but still no start. had same problem last year and replaced pdm with relocation kit and new a/c delco crank sensor . worked fine for approx. one year . just replaced ops and pump relay . still no start . any suggestions
thanks in advance
Old Oct 18, 2013 | 09:11 PM
Mase's Avatar
Try using original PMD plug,alot of extension plugs going bad lately.
Old Oct 18, 2013 | 11:52 PM
Irish_Alley's Avatar
any smoke? noise?
Old Oct 21, 2013 | 08:13 AM
richardk's Avatar
Default richardk
thank you so much , i will try plugging into the original harness , and no there wasn't any noise or smoke . it just felt like i turned the key off . i'm at work right now but will work on it when i get home , thanks again
Old Oct 22, 2013 | 10:14 AM
richardk's Avatar
Default richardk
i cannot thank you enough . the adapter plug was the problem . i remounted the pdm to the intake and plugged it to the original harness .problem solved . anyone know of a good adapter or extension that i should purchase . i feel like i need to get the pdm out of the engine compartment . again thank you so much .
Daniel Finney
Oct 22, 2019 01:58 PM
Brclouse
Nov 18, 2015 08:44 AM
Kooper
Jul 15, 2015 12:11 PM
penley`
Jun 7, 2015 04:38 PM
smokin91rs
Jun 2, 2015 09:18 AM
