7.3 injectors
Old Oct 11, 2013 | 11:13 PM
pibtrucker's Avatar
Default 7.3 injectors
im changing all my injectors on my 7.3 idi non turbo is there a specific sequence or can i just swap em
Old Oct 12, 2013 | 12:17 AM
Dortiz's Avatar
There's no sequence that I'm aware of
Old Oct 12, 2013 | 11:09 AM
pibtrucker's Avatar
iwas told that the injectors might have to go in a specific port like each one is specific for each cylider or can i just swap em one for one kinda deal.
also the wait to start light on dash doesnt come on after truck warms up if i run it it for awile and shut em off light does'nt come on and its hard to startchanged all glow plugs recently fires right up when first started though.
Last edited by pibtrucker; Oct 12, 2013 at 11:09 AM. Reason: Automerged Doublepost
Old Oct 12, 2013 | 12:45 PM
Dortiz's Avatar
do you use any fuel additive? That's my problem, everything in the systems are running correctly, but If I run just straight from the pump, doesn't matter if I just shut it off and 15 seconds later I need to run it, It won't start. I have to run some type of additive so much truck can burn it.
Old Oct 12, 2013 | 03:33 PM
4x4manonbroke's Avatar
Make sure your getting BB coded injectors, you will thank me later .... those are the best HP ones you can get to my current knowledge, I have them and wouldnt dream of going back to the stock C codes....
Old Oct 12, 2013 | 08:21 PM
pibtrucker's Avatar
already bought and installed em now it wont fire
truck blowing bueish white smoke at about 2000 rpm when in park what causes that any idea's. also fuel filter light on dash comes on when truck hits 2000 rpm while driving usually when it's in passing gear ( it's an automatic)
Last edited by pibtrucker; Oct 12, 2013 at 08:21 PM. Reason: Automerged Doublepost
Old Oct 13, 2013 | 11:21 AM
Air in fuel , if u have the fuel bowl at bottom of filter, change it out for a wix , use this number at a cross reference , BF1222 baldwin # ....
I had these same issues, I also havedone away withthe mechanical pump and gone to an electric fuel pump...
Your sucking air past the o ring. Now with a push type fuel pump, all you will see is a fuel leak, also check the actual return line Its self for leaks, as this will lower the fuel pressure and make the pulses from IP Weak .. keep posted..
Old Oct 13, 2013 | 12:57 PM
Dortiz's Avatar
Just keep in mind that when installing the electric pump to place it as close to the tanks as possible, will save you a headache in the future
Old Oct 13, 2013 | 02:40 PM
pibtrucker's Avatar
awsomethanks guys ill try it
i also noticed igot atleast three return line thingamajigs leaking fuel just put in new ijectors and o-rings
Last edited by pibtrucker; Oct 13, 2013 at 02:40 PM. Reason: Automerged Doublepost
Old Oct 13, 2013 | 03:23 PM
Yeah the return line thingamijigys is ur problem with out a doubt... hence the air in fuel diag.
