Idles OK but stalls when rpms drop fast.
Old Oct 11, 2013 | 04:12 PM
rebar's Avatar
Default Idles OK but stalls when rpms drop fast.
Iv never had any issues with my 1991 NA 6.2 But I let the wife run it, and I'm sure she forgot to add power service additive once or twice. I go to drive it, and it die's at the first stop sign. It idles OK. But if I'm running in gear and push the clutch in to stop. It drops rpm fast enough to kill the engine most of the time. I changed the fuel filter behind my intake which helped my overall power, but it still wants to die when I drop the rpm fast.
Iv learned to leave the clutch alone until the rpm's are low when stopping, then push clutch in and it stay's running.. But I'm worried something is starting to fail..
I just blew up my cummins, so I dont need another car down.
Any suggestions what to check? Or have checked? Thanks!
Old Oct 11, 2013 | 06:37 PM
racer55's Avatar
Mechanical lift pump working?
Old Oct 11, 2013 | 08:49 PM
rebar's Avatar
Guess that's the first place I should look. If it fails, can it hurt the injection pump?
This truck has about 120k with nothing but routine maintenance.
Old Oct 12, 2013 | 06:44 AM
racer55's Avatar
It will make the IP wear out faster if there is no supply/lift pump.
Old Oct 20, 2013 | 10:12 AM
rebar's Avatar
I replaced the filter and it runs great again..
The only problem is, I have a leak now. I put my hand under the filter and it was wet with fuel and ending up under the truck.
How did I screw that up? I did have to push pretty hard to get the last bottom wire clip snapped in position, but my only option now is to replace it again unless someone has another suggestion.
Old Oct 20, 2013 | 11:56 AM
racer55's Avatar
Oring get cut on the air bleed?
Old Oct 20, 2013 | 12:01 PM
rebar's Avatar
Well, fuel isn't coming out of the air bleed tube, so I don't think so.
Old Oct 20, 2013 | 12:13 PM
racer55's Avatar
Round filter in a housing or square filter on a plate?
Sometimes it is just a defective filter?
Old Oct 20, 2013 | 12:17 PM
rebar's Avatar
Square filter on the back of the intake..
Yea, I talked to Orielly and they said I could return the wix for a new one. Is the Microgard better?
Old Oct 20, 2013 | 12:30 PM
racer55's Avatar
I have good luck with wix but anything can be bad.
