Need help choosing
Old Oct 11, 2013 | 08:27 AM
Rishsd's Avatar
Default Need help choosing
I have a 2000 F250 with a 7.3. I am doing a 12 valve conversion and it is time to choose the engine. Here is what I know, I want a 12 valve (no computers), I know not to get a 53 block. My questions are what years are the better years for cummins? What are things to look for when looking for a used cummins ie. star gear turned, fuel plate replaced. Thanks for your help.
Old Oct 11, 2013 | 08:38 PM
94 12valve's Avatar
what are your power goals?
Old Oct 11, 2013 | 10:08 PM
Rishsd's Avatar
500hp
Old Oct 12, 2013 | 11:24 AM
94 12valve's Avatar
any 12 valve block will work just fine for you, if you plan on doing a twin charger set up go with the 96-98 block as it already has the secondary oil drain.
Old Dec 9, 2013 | 07:41 AM
Chrisco148's Avatar
I have a 96, where is the secondary oil drain? I will be doing twins sometime soon... Thanks.
Old Dec 10, 2013 | 12:19 PM
ClintD.'s Avatar
12 valves do not have the secondary oil drain. I have a 97 and twins. I had to add the 2nd oil drain. 24v on the other had have it.
Old Dec 12, 2013 | 11:24 AM
94 12valve's Avatar
yes the late 12v's did have the secondary oil drian encore blocks have it.
Old Dec 12, 2013 | 12:01 PM
ClintD.'s Avatar
The 98's have it I guess. Since they used the same block for the 12 & 24 valve
Old Dec 12, 2013 | 05:56 PM
AMS247's Avatar
Yup 98 12v blocks do have the secondary oil drain. Everything I have seen before that year does not have a 2nd drain though.
Chevy6.5twotirefire
Jul 28, 2015 08:29 PM
LoveCummins
Mar 22, 2015 09:59 PM
