2001 f 550 7.3 running rough
Old Oct 10, 2013 | 07:59 PM
08 Powerstroke's Avatar
Default 2001 f 550 7.3 running rough
My truck is still running rough after doing all 8 injectors.new fuel pump,and filter,new oil,and filter,did fuel tank fix,new valve cover gaskets 2,and tonight just put new Injector control module,after changing that started truck ran awful and finally got check engine light to come on showing low voltage on icp will changing this cure my issues .any help on this would be appreciated I can't sleep at night thinking of things to try
Old Oct 11, 2013 | 05:29 PM
CMCA Swartzkrautheim's Avatar
you can unplug icp and see if oil in plug leave undone and start see how runs... how many miles on new inj's? may be air in hpo system still...
Old Oct 11, 2013 | 08:21 PM
Just installed injectors last week.tried unplugging icp didn't change how it ran so by not changing how it runs you think it might be my issue? Thanks for the input
Old Oct 12, 2013 | 01:16 AM
RanchhandTCR's Avatar
How about that map sensor.... You can try unpluging it and see if it runs even rougher or smoother... Or a weak HPOP. If worse come to works get a 1500-2000psi pressure guage and pull a plug off the oil gallie and put the pressure guage on and crank it and see what kind of oil pressure you are getting, if you cant get a OBD II to read the pressures for you..
Old Oct 13, 2013 | 01:26 AM
last week but how many miles? if you drive 2 miles a day vs 200 miles a day that will vary how long it takes to work the air out of the hpo system (also how hard you drive harder you drive less miles it takes) but if last week was like 150 miles of easy driving could be airated OR did you use those cheap a@# china orings on your inj's??? I tried that cus i got em free... BIG mistake... had like 5 of em disintegrate 50% in like 2 weeks
Old Oct 13, 2013 | 07:55 AM
I have no miles on truck since all this work was done.it has not run good enough to get it out of garage all the injectors were bought from a company that remans them.As of now I have fuel bowl off gonna put all new o-rings in it the one coming in from tank was bad.The truck runs good for about 2 min then it starts running rough lot of smoke no power.hey I thank everybody for all the input.I use the truck for my construction business and being without it hurts
Old Oct 14, 2013 | 11:31 PM
white smoke or black?
Old Oct 15, 2013 | 06:37 AM
White smoke
ssmith.77
Nov 25, 2018 06:56 AM
firefighteremt
Feb 2, 2015 01:59 PM
ssmith.77
Jan 11, 2015 02:03 PM
Fishy816
Jan 11, 2015 08:31 AM
Browe347
Sep 30, 2014 11:35 PM
