need help with noise
Old Sep 29, 2013 | 04:01 PM
blackbetty's Avatar
Default need help with noise
so this noise will only happen at around 2000rpms and up it is driving me crazy that i cant figure it out and not able to pull anything with my excursion
Old Oct 2, 2013 | 09:55 AM
ktaw's Avatar
what motor is in the truck? i've heard turbo whine sorta like that and i've had a 6.7 with an exhaust manifold gaskets leaking on the driver side that sounded just like that.
Old Oct 2, 2013 | 11:46 AM
blackbetty's Avatar
It's the 7.3L I took by a place and they took the belt off and power stalled it and it didn't make the noise then it made the noise with the belt on. That's what was weird
Old Oct 4, 2013 | 10:08 PM
Tamnative's Avatar
If you took the belt off and it didn't make the noise maybe it is the tensioner. They are known to go bad. It is an inexpensive part anyway and not that hard to replace.
Old Oct 4, 2013 | 11:19 PM
blackbetty's Avatar
Wouldn't the pulley be stiff. cuz I took the belt off to change it thinking the belt was too loose and might b slipping and all the pulleys spun with ease
Old Oct 5, 2013 | 11:48 AM
Tamnative's Avatar
The bearing could still spin freely but be worn or dry,when you put tension on it with the belt it could cause it to squeal. Try spraying some WD-40 in the bearing to see if it stops,this is not a fix just a way to see if it may be the cause.
Old Oct 5, 2013 | 01:51 PM
RanchhandTCR's Avatar
Their suppose to be a certain tension on a belt tensioner too loose then a pulley can just spin on the belt and make a henderndous noise...
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
chaoticape
Jan 4, 2015 05:35 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
