no oil pressure!!!
Old Sep 28, 2013 | 06:57 AM
POWERSTROKEMANIAC's Avatar
Default no oil pressure!!!
88 7.3idi engine light came on and showing no oil pressure. I'm stumped please help.
Old Sep 28, 2013 | 01:27 PM
4x4manonbroke's Avatar
Ok, change oil filter and check it with a known good gauge, if nothing you most likely gonna want to check your radiator as well, if no oil in there your pump shaft may have sheered off, not gonna be fun, if this happened your gonna most likely want to pull all the bearings one at a time to check for scoring and galling, hope the filter is in bypass or some sort of internal failure in filter, keep us posted please , will be watching for updates
Old Sep 28, 2013 | 04:20 PM
Shaft in the op? What bearings? I noticed a few minutes ago it is smoking a good amount. Blueish white. That help?
No oil in the coolant!! That's a good sign means I don't have oil cooler or head gasket problems.
Last edited by POWERSTROKEMANIAC; Sep 28, 2013 at 04:20 PM. Reason: Automerged Doublepost
Old Sep 28, 2013 | 07:19 PM
the shaft that runs the oil pump, engine bearings, smoke is a sign of burning oil off of the cylinder walls .... possibly
could just be a bad sensor or sending unit too ... check the obvious first of course
Old Sep 29, 2013 | 05:46 PM
Never smoked before though?
Old Sep 29, 2013 | 07:26 PM
If infact ur pump is shot .... tye smoke would be due to hot cylinders ..... scoring would be my next worry if ur pump is not pumping lube , need to get a guage hooked up and verify no oil pressure ..... passenger side rear of the engine is where the guage port is located
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
