major fuel leak!!!
Old Sep 20, 2013 | 03:10 PM
POWERSTROKEMANIAC's Avatar
Default major fuel leak!!!
Well my truck randomly starts shakin and missin then I could smell the fuel. I popped the hood and smoke was Rollin out of the hood. There is a good size puddle around a couple of injectors. What has she done to me
Pictures are in my 2001 album on my profile
Last edited by POWERSTROKEMANIAC; Sep 20, 2013 at 03:10 PM. Reason: Automerged Doublepost
Old Sep 21, 2013 | 11:27 PM
4x4manonbroke's Avatar
u my friend need a return fuel line kit .... your o-rings are hard and brittle ... replace the entire kit and kabutle and you will be with out fuel leaks ( at least there ) ... make sure to use some syliglide on the o-rings or they can tear and such..
Old Sep 22, 2013 | 01:04 PM
Does the kit come with new o rings for the brass fitting that bolts the fuel line to the injector? Where is the best place to order?
Old Sep 22, 2013 | 03:20 PM
i got mine form a local place here in milton .... they build pumps and injectors .... a fuel line return kit will come with the plastc thinggys that go over the inj. and the line ( you have to get it trimmed right your self ) and spring clips to put on the lines ... real simple but time consuming ...... if that does not fix it you have a cracked injector body and will need new injectors ( which I can get for about $50.00/each (BB coded) ) ...
LariatOutlawGirl
Sep 1, 2015 02:15 AM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
