intercooler
Old Sep 20, 2013 | 02:15 AM
willis964x4's Avatar
Default intercooler
Has anyone ever though about putting and intercooler on their 6.5? What would be the pros and cons putting one on the truck? Or would it even be worth it?
Old Sep 20, 2013 | 03:01 AM
cviola2005's Avatar
I have considered it heavily.
Pros:
lower IAT
which creates a denser air charge
which makes more power
lower EGT, as long as you don't turn up your fuel
Cons:
turbo lag, depending on piping length
pressure drop, typically is 2-3psi
both of which depend on pipe size.
Old Sep 20, 2013 | 02:51 PM
Well I'm heavily considering it myself but I'm not paying damn near $1000 for an intercooler kit when I can get a universal kit for about $120 and modify it to work
Old Sep 20, 2013 | 06:48 PM
detroitdiesel idi's Avatar
Down
Waste of money..unless you upgrade turbo
Old Sep 21, 2013 | 11:16 AM
racer55's Avatar
Lots of universal kits on ebay-you need 1 for up to 500 hp.
Check PM's,I sent a link of examples.
Penninsular diesel makes a great upper intake for connecting the intercooler-some cut and modify the original or turn and mount it 180 degrees from stock to make connecting easier.
The stock turbo's really heat the charge and benefit the most from water injection or aftercooling/intercooling.
An upgraded turbo actually reduces the need for intercooling unless you strive for much higher boost than stock.
Old Sep 21, 2013 | 03:13 PM
Mase's Avatar
I guess this means you got your battery situation taken care of?
Old Sep 21, 2013 | 04:11 PM
Yea mase I broke down and bought 2 nre batteries for it. Its running like a dream now, no hard starting or anything
Old Sep 28, 2013 | 08:08 AM
great white's Avatar
Once you start crossing 8-10 psi you are in to the range where cooling the intake charge has significant benefits. That a "rule of thumb" range.
Below that, there are some benefits but not as pronounced. Generally, the added complexity and cost are seen as not a good return for the effort.
Cougdiesel
Feb 2, 2016 10:17 AM
Rooster24v
Price Quote - Request A Price
Aug 26, 2015 06:24 PM
DAR_
Jun 6, 2015 03:26 PM
Nealwheels
Jan 10, 2015 01:33 PM
roanokerivermud
Dec 2, 2014 05:42 PM
