EBP valve opened or closed
Old Sep 19, 2013 | 07:37 PM
Buckage1234's Avatar
Default EBP valve opened or closed
Do you have to remove the down pipe to see which way the flapper valve sits when it is opened or closed? Someone before me has disconnected the rod and the flapper just moves around by itself while you are driving...I tried to reconnect but there must be a trick to it or I just don't have enough hands. apparently you have to pull out on the rod while sliding back the clip on the end of it and push the valve so it lines up with the hole in the rod....very frustrating to reconnect but I am only pushing 3 boost max all the time after just putting on 4 inch pipe. Any suggestions?
RA113024
Mar 13, 2016 07:42 PM
chaoticape
Apr 12, 2015 05:45 AM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
makuloco2000
Dec 7, 2014 11:15 AM
