Coolant questions
Old Sep 18, 2013 | 02:12 AM
JunkyardDogF250's Avatar
Question Coolant questions
May sound like a dumb or 'rookie' query, but what the hell is SCA charged coolant ?
Old Sep 18, 2013 | 06:01 AM
Irish_Alley's Avatar
Part I: Choosing and Using a Supplemental Coolant Additive
Old Sep 18, 2013 | 06:36 AM
My grateful thanks for great answer and straightforward manner
Old Sep 18, 2013 | 07:58 PM
4x4manonbroke's Avatar
yes and by not using a SCA pre-charged coolant you will loose your engine real soon due to cavitation of the cylinder walls .... ..... like pitting or like its been hit by a ball peen hammer ...
cavitation is caused by several things .... such as low coolant pressure or poor flow, and the effect is caused by the piston coming up and "expanding the cylinder" and then the ignition event causes like a ripple and then the down stroke causes the coolant to pop against the cylinder walls ... hence the pitting .... which is referred to as cavitation and it will eventually go through the already thin walls of the cylinders
Old Oct 3, 2013 | 12:59 AM
mrkelton's Avatar
Old Oct 14, 2013 | 07:20 PM
JoeCole's Avatar
7.3 idi's are especially prone to cavitation from what I've heard
Old Oct 14, 2013 | 07:41 PM
Yes, the cyinders are thin and "flexable" which causes this phenominom , I have seen on youube how they explain this , will look to link it here somethime
@ 2:00 mark the small bubbles that are seen , is due to the blade cutting through the water, the sudden expansion nd contraction of the watr by the blade = cavitatio and it can and will eat through plate steel and cylinder walls too.... thought you all would enjopy this viedo
a viedo of cavitation,and pics of the damage....
Last edited by 4x4manonbroke; Oct 14, 2013 at 07:41 PM. Reason: Automerged Doublepost
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
97f-250
Nov 23, 2014 08:08 PM
Nov 12, 2014 08:10 AM
gmcmanis
Nov 9, 2014 04:49 PM
