p pump help
Old Sep 10, 2013 | 02:48 PM
jotoole's Avatar
Default p pump help
hi, I am new to this forum and have an 84 gmc that I am currently in the process of building an 01 24v motor for and am looking into a p pump conversion to possibly keep the wiring down? What will be needed as far as electronics for this motor besides gauges to get it up and going. I am also tossing the idea of a built automatic around which I believe I should be able to get a stand alone unit for. Any ideas or suggestions would be greatly appreciated.
Old Sep 10, 2013 | 10:00 PM
deck60's Avatar
get a 47rh then you wont need any electronics you can use a manual od or hook up a pressure switch for od there is a port on pass side
the money you save buying the controller put into the trans for upgrades
Old Sep 10, 2013 | 10:34 PM
jotoole's Avatar
alright thank you I will look into one of those what year of trucks were those ran in?
Old Sep 10, 2013 | 10:41 PM
deck60's Avatar
the first gen dodge diesels were manual shift. automatics
Old Sep 10, 2013 | 10:44 PM
jotoole's Avatar
ok thanks any ideas on what wiring will be needed on the motor? I am assuming that being a mechanical injection pump it will not need really anything to run, am I correct?
Old Sep 11, 2013 | 08:35 AM
fummins0214's Avatar
If you p-pump your truck all you will need to run is 12v to the pump. IIRC its the same thing as the old VE. 12v opens a shutoff solenoid allowing fuel from the delivery pump to the injection pump.That and the wires to the starter
Old Sep 11, 2013 | 11:23 AM
jotoole's Avatar
good that's all I was thinking would be need but had to make sure. this will save a lot of time in the wiring dep. which I wont complain about
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
