anti cavitation coolant additive
Old Sep 8, 2013 | 09:33 AM
97 stroker's Avatar
Default anti cavitation coolant additive
I changed my water pump yesterday and my cousin told me that 7.3s need the additive. Can I get it at AutoZone or orileys? When I asked them on the phone they have no clue what im talking about ( imagine that) Napa is closed on Sundays and my cousin said he didn't know if it would hurt to drive my truck home without the additive
Old Sep 18, 2013 | 01:45 PM
autostroker's Avatar
The stuff you need is SCA. Supplimental coolant additive... fleetguard makes some that is really good. Also you can get some from john deere. You can drive for awhile without additive but I wouldent for very long. It eats away at your cylinder linings and causes cracks without it
Sent from my SCH-R970 using Tapatalk 4
Old Sep 30, 2013 | 06:32 PM
robert1523's Avatar
Default robert1523
Ford diesel 7.3 power stroke-you should use distilled water in it.
The transmission (E40D)shifts hard in all gears.If I disconnect the battery for 30 sec. it works ok tell it goes into passing gear.1997 Ford 7.3 diesel super duty.4
Last edited by robert1523; Sep 30, 2013 at 06:32 PM. Reason: Automerged Doublepost
Old Oct 1, 2013 | 01:36 PM
Does not matter if u use distilled water or not.... the cavitation is from "bubble collapse" which doesnt care what kind of water it is..... the SCA lines the cylinders with a coating so that during the exhaust stroke the bubbles dont collapse against the cylinder wall causing it to erode.
Old Oct 14, 2013 | 02:14 AM
Thor'sHammer's Avatar
Advance auto carries "fleet charge" coolant with SCA already added. Go buy that and forget about it for a year. After a year, get some test strips and check the SCA level. If is bad, get some napa kool additive and adjust accordingly.
Old Dec 25, 2013 | 05:03 AM
turbine_dude's Avatar
Nalcool.. then it became pencool. I run fleetguard compleat in mine, You can get SCA additive from most diesel service centers.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
easttn12valve
Ford Powerstroke 2011-Up 6.7L
Mar 1, 2015 08:21 AM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
