new owner of 99 f350 7.3l 6speed
Old Aug 27, 2013 | 05:00 PM
adamsmith's Avatar
Default new owner of 99 f350 7.3l 6speed
So I am new to these powerstrokes I have owned a cummins for years.the questions are do these have dual mas flywheels?are they the same flywheels the same as the old n/a 7.3 idi engines?what kind of oil do th zf 6 speeds take?what are the more commen problems?what is the most commen reason for the cruise control to quit? Any input will most likly help thanks
Old Aug 28, 2013 | 10:11 PM
adamsmith's Avatar
Does anyone own these tucks here?
Old Aug 28, 2013 | 10:44 PM
joebob3093's Avatar
Moderator
Not where if the SD has a dual mass but the OBS do. They are not the same as the old ones. I use scheaffers ATF in my trans. Not sure about the cruise.
Old Aug 28, 2013 | 10:46 PM
adamsmith's Avatar
Do the dual mass flywheels go bad like the early ones? Up to 99 that is
Old Aug 29, 2013 | 12:15 AM
joebob3093's Avatar
Moderator
All clutches go bad. Doesn't matter if its dual or single mass
Old Aug 29, 2013 | 04:36 PM
adamsmith's Avatar
I'm not asking about the clutch I'm askin about the flywheel I know on the old ones the dual mass flywheels had a habit of letting go and breaking the bell housing
Old Aug 30, 2013 | 07:30 PM
adamsmith's Avatar
The other thing is my ac works and then peters out if I shut it off for awhile then back on it works and also all my air comes out the defrost vents hot or cold advice?
Does the cruise work off of vacume in any way?
Old Sep 1, 2013 | 12:27 PM
7.3OilPanRepair's Avatar
FormerVendor
problem with the cruise could be a lot of things. Doubt its vacuum related though. Check clutch safety switch, brake switch on the brake resivoir that kills the cruise, fuses etc.
Your air vent issue is probably a vacuum problem though. Check your vacuum pump and your 4x4 hub locks and find the leak or whatever the issue is
Old Sep 1, 2013 | 02:26 PM
adamsmith's Avatar
Thanks
Old Sep 1, 2013 | 02:35 PM
"Maxie"'s Avatar
Congrats on the Truck!
