shaved 22.5 questions
Old Aug 25, 2013 | 06:59 PM
cummins army's Avatar
Default shaved 22.5 questions
ok I have a 2006 megacab dually 4x4 and want to run the shaved 22.5 alcoas so that I can fit a regular 22 inch tire are any of you running this set up and if so what size tires are you running I cant find any clear answers on what size tires will work on this set up thanks guys
Old Aug 26, 2013 | 10:10 PM
tiremann9669's Avatar
None 22.5's have a tapered bead seat and 22's have a squared bead seat. Mounting the wrong size tires on wheels is a good way to get killed.
Old Aug 27, 2013 | 12:29 AM
you can take the 22.5 to a machine shop and have the bead milled down a quarter of an inch and run regular 22 inch tires with no problem I am just trying to figure out what tire size to run on my truck
this is what is done to the rim to make it accept the normal 22 inch tire
Last edited by cummins army; Aug 27, 2013 at 12:29 AM. Reason: Automerged Doublepost
Old Sep 3, 2013 | 11:47 PM
seanc_wa's Avatar
buy the correct wheels in the first place?
Old Sep 4, 2013 | 08:42 PM
I have done this to 3 trucks before just never a 4x4 just trying to get advise on tire size
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
95xtracab
Nov 12, 2014 05:54 PM
Nov 12, 2014 08:10 AM
