6.5 hard starting
Old Aug 24, 2013 | 02:18 PM
tonkatruckon44s's Avatar
Default 6.5 hard starting
i ChangeD the DriversValve CoverGasket On My 98 6.5 And Chaged The Fuel Filter. I Got Tge Truck Restarted And Let It Idle A Few.Minutes And Drove It For 20 Minutes, Now I Have Drove It Back And Forth To Work A Few Times(15Minutes But It StillHard Starts Doesn'tMatter Cold Or Hot. It Takes About 8 SecondsBefore It FIres Up
Old Aug 29, 2013 | 06:46 PM
racer55's Avatar
Did you damage the glow plug controller/relay or forget to solid mount it?
It grounds through the base and must be fastened down.
Old Aug 29, 2013 | 09:59 PM
I Didnt Remove It I Have A Post In The Distres Section With More Info I Think It Needs Tdco Relearn Going To Dealer Tomorrow To TrY That Sry Bouth The Cap Its A Droid
Old Aug 29, 2013 | 10:13 PM
detroitdiesel idi's Avatar
Have you jump started truck lately? Sometimes overboosting by using quick start will fry glow plug system.
Old Aug 29, 2013 | 10:16 PM
racer55's Avatar
Might also be starting in limp mode from a bad CPS/OS?
Should code with that though.
Aftermarket CPS are junk out of the box-AC Delco ONLY!
Old Aug 29, 2013 | 10:19 PM
It Starts ExactLy The SaMe Cold Or Hot. It Takes 8 Revolutions Then fires Right Up
If disconnect The Optical Sensor The Truck Wont StaRt At All But The Cps Doesn't Seem To MaTter
Last edited by tonkatruckon44s; Aug 29, 2013 at 10:19 PM. Reason: Automerged Doublepost
Old Aug 29, 2013 | 10:48 PM
racer55's Avatar
CPS is dead then I would expect-should be a service engine soon light,trouble code stored.
BWD CPS are often bad right out of the box,so special order AC Delco if need be.
Old Aug 29, 2013 | 10:52 PM
Doesn't The Cps have T Have The Relearn Procedure done
Old Aug 29, 2013 | 11:51 PM
racer55's Avatar
Some say a TDCO relearn should be done after a CPS replacement but I didn't after doing mine and no adverse affects-it's up to you if you can do it yourself or if there is a big expense involved.
I have the scan tools and procedures to do it myself and still didn't bother,but I changed out a failing Delco for a new Delco-might be different if your last relearn was done with an aftermarket CPS and your new one is a Delco?
Old Sep 2, 2013 | 12:07 AM
Rhett73step's Avatar
I have this exact same problem after a CPS replacement. it was a BWD.
