Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Problems towing with a Mega Cab
Old Aug 22, 2013 | 09:21 PM
01trailerpuller's Avatar
Default Problems towing with a Mega Cab
I recently purchased a 2006 Mega Cab. the previous owner had installed a B&W turnover ball. I went to pull my trailer for the first time and clipped the cab with the trailer though I had the 4 inch extension it. I've been told to get the gooseneck extension also, doesn't it just push it back during straight travel? Won't I still have a chance to catch the cab if I jackknife trailer when backing it up? My trailer is about 6"wider than my truck on each side.
Old Aug 22, 2013 | 10:33 PM
RanchhandTCR's Avatar
Well, honestly you proably got the wrong kind of bed to tow a trailer like that, they have a goose neck extension and yes it puts the ball farther back from the cab and the father back from the cab the less likely you will clip you cab again.
Old Aug 23, 2013 | 03:30 AM
I already have the 4"extension. That is the biggest B&W makes and their gooseneck receives are proprietary. So I can't use another company's if there is one on the market that is longer than 4".
I want to know if anybody used an offset gooseneck in a short bed and how well it works with a large trailer?
Old Aug 23, 2013 | 09:02 PM
your in a tight spot, sir. Im am somewhat confused when you say off set.
Old Aug 23, 2013 | 11:04 PM
SB316 - Extended 16 Inch Offset Gooseneck Coupler for 4 Inch ID Square Tube
Here is my truck and trailer. Has a leveling kit, that is why it looks like it is sagging.
Last edited by 01trailerpuller; Aug 23, 2013 at 11:06 PM. Reason: Automerged Doublepost
Old Aug 24, 2013 | 08:33 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i got the pull rite auto sliding hitch for my camper. works great.
Old Aug 24, 2013 | 11:53 AM
My trailer is a gooseneck. A 5th wheel hitch doesn't help me. Sorry.
Old Aug 24, 2013 | 01:55 PM
diesel pap's Avatar
yes it will. you can change the gooseneck pipe to a 5th wheel pin.
Old Aug 24, 2013 | 02:57 PM
I am on a limited budget. I can't throw $1000+ at this. Thank you for the option but it is not feasible for me, but if you know anyone who has run a off set gooseneck in a short bed and can point them my direction it would be greatly appreciated.
Old Aug 27, 2013 | 09:06 PM
diesel pap's Avatar
i know what you mean about budget. i tried every way to pull my camper on a ball like my other truck was. i can pull a narrow trailer but not a wide one on the gooseneck.
