1994 gmc 6.5 white smoke !
Old Aug 22, 2013 | 01:02 PM
Scott,s's Avatar
Default 1994 gmc 6.5 white smoke !
We had recently purchased a 1994 gmc with the 6.5 in it . Ran ok seamed like it had like a shake around 1500 rpm and recently it started running rough at idle and white smoke at idle also driving ! Also putting oil in it regularly. Has around 250,000 miles
Old Aug 24, 2013 | 09:57 AM
savvy1's Avatar
I had the same truck. It had a bad *** dump on it 1 ton. I hate to say it but the conversion Diesel was the biggest mistake GM did, converting a 454 into a diesel. The motor is a train wreck. I had one in the early 2000's and started blowing white smoke, and running rough. Head gaskets...left bank went and cost me 3000 to fix and the other side was going. I could not sell it fast enough. Thanked the good lord when I did.. sorry to be the bearer of bad news....RUN
Old Aug 31, 2013 | 02:40 AM
detroitdiesel idi's Avatar
White smoke= not enough fuel but if your regularaly adding oil i wouldnt doubt u have a cracked piston by the sounds of it. ...itd b my guess if your coolant and oil arent mixing
^ the 6.5 is definetly not a converted 454. By any means
Last edited by detroitdiesel idi; Aug 31, 2013 at 02:40 AM. Reason: Automerged Doublepost
Old Aug 31, 2013 | 10:29 AM
2004LB7's Avatar
sounds like you need to do a compression test.
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
zoomer10h
Feb 6, 2015 01:38 AM
ASarsano
Oct 15, 2014 05:33 AM
