93 f-350 non turbo 7.3
Old Aug 18, 2013 | 08:19 AM
Can't fix it's Avatar
Default 93 f-350 non turbo 7.3
Starting problem. Hard start when cold and even harder start (possibly wont start) when hot.
Also, where is location of crank shaft sensor?
Have no reason to believe there is air in the system.
Have replaced glow plug cylinoid and have been told glow plugs are good.
Please help!
Thanks
Old Aug 22, 2013 | 11:57 AM
saksranch's Avatar
You will find the crankshaft sensor at about 7:00 on the front of the engine. It takes a 10mm wrench to remove and the wires plug in. If it is bad the truck will not crank.
GarrettEvan
Jan 30, 2016 05:39 PM
honda89
Oct 17, 2015 01:08 PM
fivo2fst4u
Jul 2, 2015 06:20 PM
JSATCT860
10
Jun 26, 2015 12:13 AM
tumble72
8
Nov 27, 2014 10:31 PM
