VP finally ate it
Old Aug 17, 2013 | 10:32 PM
pastthebrink's Avatar
Default VP finally ate it
Ok. Looks like the VP finally bit the dust today. So I need some opinions before I start shopping.
a) Is the Hot Rod VP worth an extra 700 bucks?
b) I know some offer a warranty even if you do tap the pump for the Quad should I go that route or just buy a new VP and risk it
c) are there any tuners out there for an 02 that work through the OBDII port that would let me adjust the fuel without tapping the pump?
These are the questions I had but any input is welcome
Old Aug 17, 2013 | 10:56 PM
lukesdiesel's Avatar
Just go with a standard pump. Use a Stealth Cover to tap the wire.
Luke
Old Aug 18, 2013 | 01:28 AM
jigabop's Avatar
Hot rod pumps are no worth the money. They are just a so pump with the equivalent of a timing box built in. Don't waste your money on it. As for the vp44 tap...you can run your box without the tap if you're worried about warranty. You will still get canbus fueling and timing from the box.
Old Aug 18, 2013 | 11:20 AM
awesome. that is what I needed to know guys. Do I need any special tools to pull that sucker off?
Old Aug 19, 2013 | 11:12 AM
jkidd's Avatar
skip the hot rod pump. You can get a nice set of injectors and have more power and reliability than if you had a hot rod pump.
Sep 4, 2015 08:20 PM
thebarzeen
Jun 16, 2015 03:35 PM
prixibel
Jun 16, 2015 02:49 PM
wpg6.5
5.9L 12V Performance
9
Jan 7, 2015 08:19 PM
TyCarp
Dec 10, 2014 11:10 AM
