94 6.5L Wierd problems
Old Aug 15, 2013 | 12:17 AM
Rhett73step's Avatar
Default 94 6.5L Wierd problems
So Im currently working on my daily driver, its a pretty much bone stock 94 K1500 6.5T with straight exhaust. Truck has 310,000m on it, truck started to act up and just randomly stutter really hard when driving and stalling. Replaced PMD and it didnt fix it so I replaced the Crankshaft position sensor. During the replacement of the sensor I made the mistake of accidentally cranking the motor over without the CPS being plugged in. Ever since then my truck takes upwards of 7-12 seconds of cranking to start. It doesn't seem like its getting fuel during the cranking. Then engine itself is alot louder, sounds like a cold cummins. But sounds normal when it is given alot of throttle.
Kind of seems like it is stuck advanced?
Any opinions on this? I'm at a loss.
Oh, and also smokes quite a bit more than it used to. Optical sensor?
Last edited by Rhett73step; Aug 15, 2013 at 12:17 AM. Reason: Automerged Doublepost
Old Aug 15, 2013 | 06:05 PM
Mase's Avatar
If it smokes alot more than it used to then I would check the turbo vacuum and the lines for cracks.
Old Aug 15, 2013 | 06:30 PM
I already had all those replaced. It doesn't smoke under heavy throttle. Only under low load like accelerating at 1/2 throttle.
Old Aug 17, 2013 | 01:31 PM
buummppp!
I really need help with this guys.
Old Aug 17, 2013 | 06:45 PM
Mayhem's Avatar
Have you disconected the batteries for a minute yet this will reset the computer maybe erasing any issues???
Old Aug 17, 2013 | 09:40 PM
bergs's Avatar
possibly bearings let go ....our 6.5's have a bad tendency for them letting to at no particular time or reason
Old Aug 22, 2013 | 12:27 AM
cviola2005's Avatar
That was my first thought. Mayhem beat me to it
Brody Olson
Chevy/GMC Duramax 06-07 LBZ
Sep 12, 2015 11:01 PM
HardLuck
Jun 24, 2015 08:04 AM
BubbaDT55
Apr 12, 2015 10:47 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
HeavyChevy95
Jan 11, 2015 04:31 PM
