fittings required to run assasin w/ 1/2 inch lines...
Old Aug 6, 2013 | 09:36 AM
rightwinger's Avatar
Default fittings required to run assasin w/ 1/2 inch lines...
has anyone ran the assasin pump with 1/2 inch lines? I posted this on another forum but apparently DTT has such a bad reputation that I was told by a moderator to not post anything about them on that forum and to go to another forum. I'm not here to argue if there company has or hasn't had issues, however the pump seems to be good and if I can source one from another vendor and not have to deal directly with DTT I would like to run the setup with 1/2 inch lines since the kit they sell only comes with the 3/8 inch lines. I was curious if anyone has done this and if anyone could be so kind as to tell me what all fittings will be needed. I talked with Jamie from CPP and he was very helpful and linked me to a 1/2 inch kit they sell, but this is for the FASS pump, just not sure if it will need more fittings or not. Thanks in advance.
Old Aug 6, 2013 | 11:15 AM
jigabop's Avatar
you likely won't know unless you already have one of their pumps...I can imagine jamie from CPP, or vulcan performance, or even a local hydraulic supply shop can get any fitting you need...
those 08 JIC fittings are just hydraulic hose fittings...
Old Aug 6, 2013 | 01:30 PM
pastthebrink's Avatar
Vulcan Performance will have all the fittings you need. You can give Eric a call and he will help you with what you will need.
