Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
Broke water separator tank valve lever
Old Jul 25, 2013 | 08:36 PM
SD350's Avatar
Default Broke water separator tank valve lever
I was opening the valve to drain my water seperater and the lever on the valve snapped off. I finished changing filters drove the truck 3 miles and let warm up and I didn't see any fuel leak out. I couldn't tell if the valve was open or shut but if its not open it's close to being open. My question is it safe to drive it tomorrow I have a 30 mile commute one way to work and will get a rebuild kit on my way home. If it works its way open some how will I loose a lot of fuel? My tank is almost on e.
Old Jul 27, 2013 | 02:41 PM
gunman41mag's Avatar
Moderator
Did you put a new valve ???
Old Nov 18, 2013 | 11:53 AM
SD350's Avatar
no i havent yet. Im guessing i will get a message when it needs draind from what ive heard so ill just do it then.
Old Nov 19, 2013 | 09:26 AM
Moderator
You should be draining it every month
RA113024
Mar 13, 2016 07:42 PM
markv8993
Jun 21, 2015 12:24 AM
LTreis702
Feb 14, 2015 12:52 PM
yams
Dec 7, 2014 12:51 PM
