2003 chevy needs diagnosed
Old Jul 17, 2013 | 01:05 PM
brettdfny19's Avatar
Default 2003 chevy needs diagnosed
i have a 2003 chevy i just use it for a farm truck and to go to work... i dont race it and i do all my own work.
she has had a issue with the instrument cluster where it wont come on like it should or doesnt come on at all. i pulled the dash gauges and checked if there was a loose wire and their wasnt one. now i have replaced the hvac blender in the dash with a new ac delco and now the blower isnt working on any setting. last night on the way to work the turn signals stopped working but the 4 ways worked. about a hour into the trip the turn signals started to work again and threw a ck eng light. this morning i went to leave work and it wouldnt start unless i wiggle the relays ( it may just have stared for another reason but thats what i tried prior to turning the key. i also checked the battery cable connections and they were snug prior to opening the fuse box. and the ck eng light was on. a week ago i went to start it and it wouldnt, low amperage. i put a charger on it and it started perfect. two weeks ago i was diagnosing a ac problem when i was trying relays and thats when she first threw a ck eng light for the first time. i just got back from advanced and they pulled 15 codes from the truck and here they are. im thinking it is a computer issue with the eng.
P0090 Fuel Pressure Regulator 1 Control Circuit
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
DTC U1026 Loss of ATC Class 2 Communication
DTC U1024 Loss of serial communications for class 2 devices
DTC U1041 Loss of EBCM Communication
DTC U1152 Loss of Data HCM
DTC U1000 Class 2 Communication Malfunction
DTC U1018 Loss of serial communications for class 2 devices
U1800?
C0379 - Front Axle System
C0327 - Encoder Circuit Malfunction
C0306 - Motor A or B Circuit
B-0790 - Wiring problem in transfer case control module (TCCM)
thanks fellas any help would be appreciated.
Old Jul 17, 2013 | 05:56 PM
j johnson's Avatar
sounds like to me that mice may have chewed on some wires under the fuse block...just my 2 cts...
Old Jul 22, 2013 | 08:39 AM
biged681985's Avatar
its either bad wiring or the ecm is about to go caput. id lean more towards wiring
Mar 6, 2015 08:10 AM
Dec 3, 2014 09:40 AM
Nov 20, 2014 06:20 PM
Oct 30, 2014 11:50 AM
Oct 16, 2014 07:10 PM
