Melting headlight switches, relays, and HIDs
Old Jul 8, 2013 | 08:08 AM
JBearSVT's Avatar
Default Melting headlight switches, relays, and HIDs
So, I've been burning up headlight switches at a rate of about two per year. I always drove with my lights on, and I drive about 50K a year, so they get a lot of use. The Chrysler ones only last a few months longer than the NAPA ones, for twice the cost. Through my research here, I've gleaned that the solution is adding relays.
For some time, I've wanted to put in HIDs, but I've been waiting until I get the headlights squared away, thinking that I should gert them working as they should before I start modifying them further. Then I had a thought the other day, that perhaps I can kill two birds with one stone here.
My question, for those familiar with installing HIDs on these trucks, is: do the kits include relays for their operation? All I know is that they have special bulbs and ballasts, but if they come with relays as well, then upgrading to HIDs would solve the switch melting issue that's been plaguing me for years. Anyone know?
Old Jul 12, 2013 | 02:56 PM
JBearSVT's Avatar
Hm. Well, in other news, LMC truck sells an HD harness upgrade for $30 that is pretty much plug and play, and runs none of the power through the switch or even any of the factory wiring. Put it in today, problem solved, very nice piece. Highly recommended.
Old Jul 12, 2013 | 08:26 PM
mysterync's Avatar
There's a recall or tsb on the switch for a updated design with a rewired harness for the melting switch. There's also some talk about a updated harness with a relay from dodge that's very affordable. But I've not had to use anything like that.
Old Jul 12, 2013 | 09:01 PM
JBearSVT's Avatar
I looked into it, none of my local dealerships were able to come up with anything. At all. Lots of homework that went nowhere. Got tired of fighting with Dodge about it and went with this, and I have to say I'm pretty impressed with the product.
Old Jul 12, 2013 | 09:12 PM
mysterync's Avatar
I've got the part numbers I'll post Monday just in case someone else needs them.
