need suggestions
Old Jul 5, 2013 | 10:26 PM
jddiesel19's Avatar
Default need suggestions
Hey guys I have a 02 lb7 just had injectors replaced, headgaskets, arp headstuds , water pump...and I'm still having problems with it when I'm rollin doin like 40 and I fet into it then let off it'll puke out white smoke.not burning oil or coolant either.basically I'm wondering if anyone can give me an idea of what's up or a way to unload my truck to a deal without losing my shirt bc I'm in the process of expanding my dairy but I need a solid runnin pickup thanks for any or all help/suggestions
Old Jul 12, 2013 | 01:25 PM
willsaratoga's Avatar
Coolant Or injectors
was is white smoking before the work that is why you had it done ?
Last edited by willsaratoga; Jul 12, 2013 at 01:25 PM. Reason: Automerged Doublepost
Old Jul 12, 2013 | 09:41 PM
jddiesel19's Avatar
yes
Old Jul 13, 2013 | 08:23 AM
Everything I can find about it points to the injectors possible fuel filters or fuel system.
It is also consistent with an overfuel condition that can be caused by many many different things, from injectors sticking open too long, or stuck open, to engine oil being pushed passed rings, to a blown turbo seal, etc. etc. etc.
Hyjacked post.
Last edited by willsaratoga; Jul 13, 2013 at 08:23 AM. Reason: Automerged Doublepost
Old Aug 16, 2013 | 11:12 AM
sessions's Avatar
white smoke is a very strong indicator of timing issue. Most likely an injector problem or a tuner malfunctioning. I always remove tuner (if the truck has one) before any trouble shooting. Where did the injectors come from you installed?
Old Aug 19, 2013 | 06:26 PM
Blavoie1990's Avatar
replace the filter to, easy cheep mind releif just to make sure its not that. also if the fuel system is pulling in air into the system can cause white smoke.
GarrettEvan
Jan 30, 2016 05:39 PM
bud0994
9
Jun 8, 2015 06:15 PM
Montana_flc
Jun 4, 2015 06:19 PM
billy-bob
5.9L 12V Performance
Jan 23, 2015 08:48 PM
Dunn
99-03 7.3L Performance
Oct 26, 2014 01:44 PM
