Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
U joints
Old Jul 2, 2013 | 10:28 PM
SD350's Avatar
Default U joints
I think my u joints need replaced I have 90000 miles on the truck and when I go into reverse it makes a squeaking noise. Has anyone had this problem before ?
Old Jul 2, 2013 | 10:49 PM
RanchhandTCR's Avatar
U joints dont squeak, but it may be your carrier bearing, you can crawl underneath and pull on the u-joints and see if any move if not them something else.
Old Jul 6, 2013 | 10:29 PM
liftaford6.4's Avatar
Default U-Joints
I had to replace the U-joints a few months back at 71k. If I can recall it wasn't a squeaking, but more of a clicking. Mostly in Drive, not in reverse. If it's not that bad I would spray some royal purple on em until they go out. You'll know when they go out.
Old Jul 7, 2013 | 10:45 AM
gunman41mag's Avatar
Moderator
My U-joints make a big clank sound & i'm at 73,000 miles
Old Jul 7, 2013 | 11:49 AM
If you hit the throttle and let off and hear a clank sound, one is bad somewhere, its hard to tell by noise, because I check by touching them and wathcing the caps and see if it will move in and out of any of the caps on the u joints.
Old Jul 7, 2013 | 12:10 PM
Moderator
I know when my u-joints need to be replace, cause i have to pick it up my drive shaft from the street
Old Nov 18, 2013 | 11:53 AM
SD350's Avatar
Found out the noise i heard was my rear drum break assembly. It was pretty much in 100 pieces. I did also need new U-joints i could feel the play in the drive shaft when letting on and off the gas.
wildbill
Oct 2, 2015 01:56 AM
LawdawgSHPD
Aug 21, 2015 06:23 PM
CumminsCoalRoller24/7
Jul 5, 2015 06:30 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
