Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
F800 ready for fun.
Old Jun 29, 2013 | 09:42 PM
tnpete's Avatar
Default F800 ready for fun.
Don't have the hitch mounted yet. But did back up to where its level and did some checking. 5th wheel will be mounted behind the axle almost at the back of the bed. Pin will be about 12" from the back. Thinking everything is going to work out great with the bed like it is. Will be boxing in the cutout in the bed for the 5th wheel and goose neck hitch with Diamond Plate. Bolting it in. That way if I need to work on air lines or air bags back there I can get into them.
Old Jun 30, 2013 | 11:54 AM
Red_Rattler's Avatar
High Tech Redneck
Hell yea that'll be a badass tow rig! Whats the specs on it, anymore pics? do a short lil build thread on adding the hitch too if you could
Old Jun 30, 2013 | 12:07 PM
tnpete's Avatar
1987 Ford F800 with the 7.8 Ford Diesel built in brazil RT6610 Road Ranger 10 Speed trans, Rockwell rear with 4.56 gears, Air Ride along with Air Ride seats,60" Stand up sleeper with cabinets all around the top and space for a fridge and other stuff along with heat and AC back there, 9ft long x 8 ft wide Hauler bed, 24.5 Alcoa wheels and 11R-24.5 tires, Air brakes so stopping is not going to be an issue. As the truck as a single axle dump would gross more then it will weight with the camper. And plenty of brakes to stop it as a Dump truck
More Pics
Before taking the big Fuel tank off the back
Without the tank but still needs cleaning
Old Jun 30, 2013 | 12:44 PM
High Tech Redneck
Is it registered as an RV or truck yet? That thing would be perfect for luggin around my pull truck nice find
Old Jun 30, 2013 | 01:06 PM
tnpete's Avatar
Will register it tomorrow as an RV. Unless I can't pull my Gooseneck trailer to haul our Heating Pellets or my tractor for personal use. Then it will be tagged as a private Pickup.
Pete
Old Jun 30, 2013 | 05:23 PM
High Tech Redneck
No one needs to know that but it should still be able to be registered either way since the truck itself has a sleeper
Old Jun 30, 2013 | 06:31 PM
tiremann9669's Avatar
Nice tow rig, I used to run a F800 knuckleboom truck with the 7.8, wasn't bad on power in stock form.
Old Jun 30, 2013 | 07:07 PM
tnpete's Avatar
What trans did it have in it? REmember what gear ratio was under it?
I know with mine having the Road Ranger 10 speed and 4.56's its turning about 2000RPMS @ 55 MPH Tops out at 2800 RPM's and about 68 to 70 MPH.
Pete
Old Jun 30, 2013 | 07:40 PM
Pete
The one I drove had a 5 speed with a 2 speed rear but I have no idea on gear ratios
Old Jul 2, 2013 | 06:16 AM
tnpete's Avatar
Will be hunting a 4" Muffler or Resonator ASAP. The droan in the cab is not going to work for me. On a long trip I would have to wear ear plugs. Love the looks of the Chrome stacks, and when you get on it the trail of smoke. But my hears don't like the sound. So anyone know of a cheap fix? If I can't get it quit in the cab, They will only be for show. Run the exhaust all the way to the back. Being the truck is 204" Wheel base think that would get the sound way back to where theres no issues in the cab
Here's a sound Video of it starting up and the sound sitting still. Look over the country boy voice.
