LB7 help
Old Jun 22, 2013 | 08:48 PM
Walker.B's Avatar
Default LB7 help
my dad gave me his 2002 Chevy 3500 LB7 he thought the injrctors were bad I cheeked the disel was bad like it had something in it so I removed the fuel tank and I toke the lines lose cleaned the tank and lines flushed bought a rebuild kit for the fuel filter housing and primer I rebouilt it reinstalled put fresh diesel and primed the truck is still a no start it's like it's not getting fuel any ideas?
Old Jun 27, 2013 | 08:17 PM
Walker.B's Avatar
any ideas guys i don't know what to cheek next should I pull the cp3 and have it tested or injectors?
Old Jun 28, 2013 | 01:36 AM
2004LB7's Avatar
if he thought the injectors where bad he was probably right. the LB7s where notorious for bad injectors.
the ECM/FICM will not open the injectors until it sees at least 10 MPA (1450 psi) on the high side. if the pump is primed and you know you are getting fuel to it but it doesn't fire then the return rate on one or more injectors is likely too high.
try replacing the short section of rubber hose on the output of the filter with a clear one so you can see if you are getting diesel and there is no air getting in.
you can also take the input to the filter and rig a jug and line to feed diesel straight into the filter. with this you can see if it is pumping fuel or not.
if you have access to a scan tool that can display the actual and desired fuel pressure that will make diagnoses easier.
Also, how many miles on this set of injectors and did you put a new filter in?
Old Jun 28, 2013 | 11:14 PM
Walker.B's Avatar
I did change the filter and it has 173xxx miles and be for it became a "no start" it had gray smoke after idling a while and at talk off after long idle times and just to be sure I primed it right how do you prim it? thanks for the help.
Old Jun 29, 2013 | 02:37 AM
2004LB7's Avatar
173K miles is pretty good for a set of injectors. i would bet they are shot now, especially since it was smoking.
priming it is easy. loosen the bleed screw on top of the filter housing. pump the primer bulb until fuel comes out. tighten up the bleed screw. be careful not to over tighten as it is plastic and cracks with little torque. this is one of the spots that leak often and causes loss of prime. then pump the primer bulb some more until it is hard.
you may need to keep pumping the primer bulb if the engine doesn't start. no need to keep opening the bleed screw each time.
off course if the return rate on the injectors are too high then the bulb could get hard and the truck will still not start.
Old Jun 29, 2013 | 11:59 AM
Walker.B's Avatar
ok that's how I primed it and what's the best way to fix this should I replace CP3 and injectors or just the injectors. what kind should I get bosh or industrial injection? it's gonna be a while before I can buy them I'm only 16 but I would like to know which ones to save up for. and will the injectors go out again after I change them? if so how meany miles should I get out of a set. thanks
Old Jun 29, 2013 | 09:55 PM
2004LB7's Avatar
as far as i know Industrial Injection sells Bosch injectors so you should be getting the same thing. as long as they are Bosch re-manufactured you should be fine.
i would replace the injectors and see how it runs then decide if it needs a CP3.
as far as how long they should last is up in the air. from what i gather it seems that most will go between 80k to 120k miles but some only get to 25k and some all the way to 225k.
Old Jun 29, 2013 | 10:07 PM
mysterync's Avatar
They also shelf house remans which are less reliable IMO.
Old Jun 30, 2013 | 12:35 AM
Walker.B's Avatar
also I went to a diesel repare shop to see a guy I knew he said he would replace them with 10% over stock. I'm not looking to build power or anything so I was thinking stock injectors what do you guys think. how much will a set of injectors cost me the guy at the diesel place said $2500 for him to order and me install
Old Jun 30, 2013 | 01:09 AM
2004LB7's Avatar
10% will likely make no noticeable gains. you would need something like 30 overs to get anything meaningful and an EFI Live tune to make it run right.
stock injectors could deliver enough fuel to bend rods and brake other hard parts. so the decision to keep stock size injectors is a good one.
check out Lincoln Diesel. prices are good and support is also great. did mine for about less then 2 grand. Web Store - Lincoln Diesel Specialties
