6.7L pistons in a 5.9?
Old Jun 18, 2013 | 03:25 PM
dixierebel0213's Avatar
Default 6.7L pistons in a 5.9?
ive aquired five good 6.7L pistons and one bad. as far as i can tell compared toa 5.9 the pin is the same height the same and the only difference is diameter the 5.9L is 102 mm and 6.7 is 107mm, i know if i rebuild mine i will need to bore it, so i would like to buy one 6.7L piston and stick them in. just wondering if there is enough block to punch it to 107mm. havent found anyone who has done it but im sure if it can be done someone has. would make it a 6.5L or 395 ci.
Old Jul 14, 2013 | 12:56 AM
1stgenblowingsmoke's Avatar
It won't work, a 6.7l block dimentions n stuff are the same but there's one less water jacket in between two cylinders to fit the bigger bore, you can run 6.7l rods n get a 6.2l displacement but not pistons.
Old Jul 14, 2013 | 01:01 PM
I'm AssuMing You Mean ThE Crank Bc Changing The RoDs Just Changes Piston Height Not stroke
Old Jul 14, 2013 | 06:18 PM
yeah my bad.
Old Jul 18, 2013 | 11:15 AM
94 12valve's Avatar
running the 6.7l crank will also require some pretty costly pistons to make it work correctly
Hmfman91
8
Jul 3, 2015 05:52 PM
brand97
For Sale
Jun 30, 2015 09:14 AM
elbedonie
May 19, 2015 10:16 AM
bubbs33003
May 3, 2015 11:31 AM
EasTxOilfields
Mar 31, 2015 09:03 PM
