02 cummins no oil pressure
Old Jun 17, 2013 | 10:59 PM
ffemt44169's Avatar
Default 02 cummins no oil pressure
Hey yall. I was commin home from work and the check gauge light came on and chimed. Checked my gauges and NO oil pressure at all. Pulled over and checked the oil. Was a little low but not below the add. Topped the oil off and started it up gauge went to about 30 and then after about 30sec it dropps to 0 again. Any suggestions thanks
Old Jun 26, 2013 | 07:06 PM
Red_Rattler's Avatar
High Tech Redneck
My guess is the sender for the gauge is on it way out or the connector to it is loose any codes pop up?
Durtyd09
Nov 11, 2015 01:43 PM
jhprice
Mar 29, 2015 09:36 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
coors_man_2005
Dec 15, 2014 10:23 AM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
