98 6.5L wont run need help
Old Jun 13, 2013 | 01:46 PM
98chevystacked's Avatar
Default 98 6.5L wont run need help
so what the truck is doing is i go to crank it over and i get a little studder like it wants to start then i can just keep on cranking and nothing will happen ive changed the lift pump/ shut off solenoid/ crank sensor/ and injection pump i can get it running off either but i really really hate doing that so and help would be greatly appreciated.
Old Jun 13, 2013 | 03:29 PM
Mase's Avatar
When mine only started on WD-40 not either (ever) it was boost sensor on the intake?
Old Jun 13, 2013 | 06:48 PM
Redneck79's Avatar
Just wondering if you are getting proper sump? if the motor air locks the diesel before the injectors it wont prime itself. I put an air hose with a rag around it into my full fill tube and have a friend crank on the truck with their foot on the floor while i am putting the air to it. hop this helps 6.2 and 6.5 have the same prime issues some times.
Old Jun 20, 2013 | 03:12 PM
tried that it didnt work thanks for the info though mase
Daniel Finney
Oct 22, 2019 01:58 PM
vin_diesel
Mar 1, 2016 01:43 PM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
HeavyChevy95
Jan 11, 2015 04:31 PM
duanedwc
Dec 13, 2014 12:36 PM
