Over heating when pulling a load
Old Jun 11, 2013 | 09:30 PM
Derbygod's Avatar
Default Over heating when pulling a load
I bought a 2003 chevy duramax a couple months ago hauled a couple of cars with no problem I have now installed a edge attitude with juice programmer and a cold air intake and was hauling a car and it started to over heat I was running around 70 so I slowed down and the temp droped On the way home I had 2 toyota trucks on the trailor and it over heated agian so I unloaded one and it dropped but still stayed hot .Once the truck wasnt pulling anything it runs cool any help would be great. The truck has 164000 miles and is a duelly with cat deplete
Old Jun 12, 2013 | 09:12 AM
MillerBoyzDiesel's Avatar
Is your fan clutch working alright? a/c condenser, intercooler, radiator fins clean? Coolant level correct. What setting are you running the programmer on?
Old Jun 12, 2013 | 07:30 PM
Derbygod's Avatar
I was running in the tow mode on my edge and had the tranny in tow also The first two cars I hauled I didnt have the edge could it be over fueling my truck? I will check the raidator and clutch fan but if something was wrong with them wouldnt it overheat all the time?
Old Jun 28, 2013 | 02:17 AM
2004LB7's Avatar
not necessarily.
i have been running for the better part of a year with out any fan at all and it doesn't over heat (except once). granted it will run a little on the hot side when driving below 30 mph for extended time. i dont tow much so i have been able to get away with it like this
towing puts a much greater demand on the cooling system. when you add a programmer and increase the fuel the cooling system now has to dissipate the extra heat generated and can overheat easier.
i would, as suggested above, check the cooling system and maybe even a coolant flush and replace the thermostats.
mattshow123
14
Mar 12, 2018 01:41 PM
Brclouse
Nov 18, 2015 08:44 AM
carid
Diesel Bombers Sponsors
Jun 22, 2015 09:33 AM
timracerx
Apr 14, 2015 10:28 AM
Diesel combi pete
Nov 16, 2014 12:26 PM
