tire size?
Old Jun 8, 2013 | 07:02 PM
willis964x4's Avatar
Default tire size?
I have a 1997 Chevy k3500 dually and its running 235/85/16 tires and my tires r junk! And I was wondering what if any different sizes I could put on it, its all stock suspension and my back duals seem extremely close so idk if I can go with a different size tire or not? Any suggestions? Can't afford new tires so I have to look for a good used set and for some reason where I live its very hard to find a set of 235/85/16s
Old Jun 8, 2013 | 08:54 PM
detroitdiesel idi's Avatar
I run 265 75 16stheyd give u more top speed with your 410 gears and arent as wide as ur 85s
Old Jun 8, 2013 | 09:19 PM
tiremann9669's Avatar
Actually they're wider the first number in the size is the width, they're also shorter (second number in the size) so you would get less top speed
Old Jun 8, 2013 | 09:41 PM
So tiremann9669 what do u suggest?
Old Jun 8, 2013 | 09:44 PM
Mase's Avatar
Willis call batteries now motor sports in Jasper,they have used tires.I'm running 285/75 16 but I doubt you could get away with that on a dually.
Old Jun 8, 2013 | 10:14 PM
Thanks mase ill definately be giving them a call, and yea I don't think ill get away with running 285s either, I'm running them on my half ton
Old Jun 9, 2013 | 10:58 PM
Anyone else have anymore suggestions?
Old Jun 10, 2013 | 06:38 PM
235/85R16 or 255/ 85R16, or 7.50R16 You might get away with running 265/75R16 but like I said they're a little shorter and a little wider. Shorter tires will hurt your milage and taller tires like the 255/85's will help it a little if you even care about that
If you load that dually you wanna stick with a 10 ply (load range E) tire
Last edited by tiremann9669; Jun 10, 2013 at 06:38 PM. Reason: Automerged Doublepost
Old Jun 10, 2013 | 08:33 PM
Mileage idc about, I definately need to stick with 10 ply because I haul my 7 foot bush hog for my tractor on it, and I use to pull my skidsteer around and I use to pull my dump trailer with 5 tons on it
Old Jun 14, 2013 | 04:18 PM
jonesjj35's Avatar
Ok so what is the biggest tire I can run with my 2000gmc 3500 junkyard save...
salty4life
Aug 20, 2015 10:46 AM
B737 Capt
Jun 9, 2015 06:34 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
LikeTheFabric
Ford Powerstroke 2011-Up 6.7L
Mar 10, 2015 01:18 PM
