'94 6.5TD problem
Old Jun 8, 2013 | 03:07 PM
FXSTC's Avatar
Default '94 6.5TD problem
Hi guys.
I bought a '94 Chevy 2500LT with a 6.5 TD as a backup in case my dually went down.
The truck has problems and I need help.
BTW, besides turning up a Cat 3406, I know nothing about diesels.
This is what it's doing and what i've done so far:
The engine has 212k miles, and it's missing, smoking, has fuel in the oil, and is vibrating.
Everyone said fuel injectors. So, I loosened each one to see which one(s) were bad.
The two rear ones on each side didn't effect the engine any when I loosened them, so I changed them out.
Same as before. I did check one I put in, to see if it would idle rougher if I loosened the fuel line, and it acted as before. No difference in the way the truck idled. Bad injector maybe?
I didn't check the other one to see if there was a change in it because it's a pita to get to, it's the back one on the passenger side. I will, i'm sure, if I can't find anything else to check.
Truck takes a few to start if it sets for a week or two, but after starting, then it starts right up.
Since it is a '94 model, I don't want to spend a fortune repairing it (which is why it isn't in the shop ).
Any help would be appreciated.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
thurobred1320
May 5, 2015 09:26 PM
Oct 14, 2014 03:30 PM
