Tranny bands?
Old May 29, 2013 | 01:11 PM
Chad96Dodge's Avatar
Default Tranny bands?
So I want to get some more info in this subject. I have heard by adjusting the bands will help prolong the life of the tranny? any one got a link or pics to help me out? 96 Dodge 12V thinks its the 47RE?
Old May 29, 2013 | 02:34 PM
4x4manonbroke's Avatar
Ok ... one is on the drivers side above ur shift linkage .... you will need a 3/4 wrench and a 5/16... Loosen the jam nut and finger tighten the center bolt finger tight ... the with the small wrench u will tighten the center ( which is the band adjustment bolt its self) ... about 1/4 turn ...or 72 in pounds if u have the wrench for it .... then back the center off 2 whole turns and jam it ....... The other is in the pan .... same thought pattern .. back off the jam nut and tighten up the centrr to 72 in pounds .... not pounds feet what ever ya do ... inch pounds only .... once tightened up to 72 in pounds ... turn it back 3 full turns and jam it ...... This will help ur trans shift better and last longer due to lack of slippage wich makes friction and heat which can destroy parts quickly
Old May 29, 2013 | 03:30 PM
Thanks for the info!! that is great help. I did some net surfing and came across this great site as well. Ram Diesel Index tons of info.
Old May 31, 2013 | 09:47 PM
sweet ... thanks ..... will have to set that on my fav.
Old Jun 4, 2013 | 09:46 AM
I did for sure. its got so much info its great!!
InheritedDiesel
Jun 3, 2015 09:39 PM
wilki
Feb 12, 2015 09:04 AM
Ol Goat
Jan 22, 2015 02:16 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
