Slack in the drive line.??
Old May 28, 2013 | 08:43 PM
Cwizzle's Avatar
Default Slack in the drive line.??
I have an 03 cummins 6speed and when i let off the clutch from a dead stop there is a whining/grinding like noise then if i hit the throttle it goes away. At highway speeds if you let off then give it more throttle it jerks a little.?. Checked the u joints all good should i look towards the rear axle? Tranny tailshaft??
Old May 29, 2013 | 09:25 AM
Bryce's Avatar
Sounds like the clutch is going out on you. Does it make the noise when parked, idling, with trans in neutral and not pushing on the clutch?
Old May 29, 2013 | 04:50 PM
Cwizzle's Avatar
Not the clutch. No noise when idling. Ended up being the rack and pinion. Replaced it everythimgs all good now thanks anyways bud
|WYG|SS
May 7, 2015 04:57 AM
Mar 19, 2015 08:10 AM
6.5dieselman
Feb 26, 2015 04:45 PM
Feb 12, 2015 03:10 PM
MAC4232
Jan 28, 2015 01:46 PM
