2002 7.3 cranks wont start
Old May 27, 2013 | 01:59 PM
alias™'s Avatar
mad 2002 7.3 cranks wont start
ok heres one that even has the ford techs stumped. i just bought a 2002 superduty w a 7.3 in it has had the ipr cps and icp replaced new batteries fully charged has plenty of fuel and pump works fine, hpop builds up to 2800 lbs when cranking. won't show any codes. i have switched out the pcm and idm the thing cranks good has smoke while cranking. will start and run on either after glow plugs time out using very little as i don't like using it, has voltage to gps all checked out .7 or less ohms, injectors ohmed out at 2.5 to 2.8 thanks in advance for any help
Old May 30, 2013 | 11:35 AM
smoran22's Avatar
did you ohm the injectors independently under the valve cover or through the valve cover gasket connector?
Old May 30, 2013 | 06:28 PM
alias™'s Avatar
Steve thanks for the reply. i checked through the connector on the valve cover gasket. checked compression tues. changing engine now 285 lbs compression first cylinder well #2 actually, try didn't even bother checking the others
Rusher48
Jul 2, 2020 08:39 AM
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Domrig13
Dec 12, 2014 01:24 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
