DTC 27
Old May 25, 2013 | 10:00 PM
Andrew4118's Avatar
Default DTC 27
Can anyone tell me what could be the problem if Ive already changed the accerator pedel already. I changed it and still get the same code after disconneting the batteries to clear the codes. Im also getting a DTC 44 for a O2 sensor thats not even on the truck. Grounds are good unless there is a broken wire somewhere that I cant find. Is it possible it could be the PCM? Im at my whitts end. Sometimes it starts and runs great. Other times its starts hard and shifts hard as well and I lose OD. Its a 1994 2500. Any suggestions? Thanks in advance.
Old May 26, 2013 | 06:11 AM
Mayhem's Avatar
I was getting that code the I changed my Crankshaft Position Sensor ,(CPS) had all them symptoms except for the OD issue If you decide to change yours do not put a BWD brand in the truck as they are crap out of the box get AC.DELCO or NAPA only
Dbleo351
Nov 20, 2016 09:34 AM
JJ Diesel
Mar 20, 2016 07:39 PM
boneheaddoctor
Jan 15, 2016 06:19 PM
ctjkelley
Jun 3, 2015 06:01 AM
daniel2500
Apr 27, 2015 06:04 AM
