Head gasket or injector sleeves?
Old May 24, 2013 | 02:49 PM
Slowlb7's Avatar
Default Head gasket or injector sleeves?
Hi I'm new on this site, I just picked up a 02 duramax with 226k miles crew cab for 3500 bucks
Problems, for every 300 miles I add a gallon of coolant no visable leaks small water pump leak only couple of drops, from what I've read when the head gaskets go on these trucks they pressurize the coolant system and they spill out overflow tank, not happening here so I'm assuming its burning it. I can run the truck all day and remove coolant cap and there is no pressure in tank.
Replaced coolant cap
Bleed coolant system
No coolant in oil
What you guys think? Injector sleeves?
Old May 24, 2013 | 02:55 PM
MillerBoyzDiesel's Avatar
Injector cups would usually leak around orings at top putting coolant in your oil. I would lean towards hg. They don't always push coolant.
Old May 25, 2013 | 07:40 AM
Slowlb7's Avatar
Ok thanks time for some head studs for a good foundation for some power add ons
Adam65
Jan 9, 2015 11:50 PM
Diesel Addict
Price Quote - Request A Price
Dec 10, 2014 06:52 PM
turbodiesel123
6.2L & 6.5L Performance
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
1994cummims
9
Oct 15, 2014 11:37 AM
