Ford Excursion 99-05 7.3L and 6.0L All Discussion on the Ford Excursion with 7.3L and 6.0L Power Stroke V8 Turbo Diesel Engine. Including Bombs (Aftermarket)
My 7.3 won't start seems its not getting fuel
Old May 23, 2013 | 03:48 PM
Mattmanmcl's Avatar
Default My 7.3 won't start seems its not getting fuel
Hi there I have a 00 f250 with a 7.3 it's chip and has a turbo upgrade was running fine till the other mourning it was hard to start . When it did it was like it was having trouble getti g fuel or when a cold desil dies on a cold mourning I gave it a little of the peddle and she smartened up the following day she just wouldn't start gave her a shot of starting fluid to see if shed run long enough to get the trouble codes but she don't wanna start even with a shot of juice now the hp pump filter and all regular maintenance is done so if anyone has some advice please feel free to share
Old May 24, 2013 | 10:16 AM
MUDGRIP's Avatar
Fuel pump along frame rail. Pull fuel filter from canister and have someone turn key to run. See if canister fills up. If not... its the pump.
Old Mar 31, 2014 | 09:09 PM
PSP DIESEL's Avatar
Well i got a few questions, What is your diesel gauge reading? remove the fuel separator cap and cycle the ignition forward how fast does the fuel bowl fill? if you have a scanner do you have any stored DTC?
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
penley`
Jun 7, 2015 04:38 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
