mac plug on 12v
Old May 20, 2013 | 10:03 AM
cummins Pride's Avatar
Default mac plug on 12v
iv been hearing that i can buy the 12 doller mac plug and put on the back of my pump to allow the shaft to moe farther back and forth and gain 10 to 20 hp does anyone on here done this or have any experience with doing this thanks
Old May 20, 2013 | 10:49 AM
MillerBoyzDiesel's Avatar
its on the front of the pump. I will allow more rack travel for more fueling. Nice cheap upgrade.
Old May 20, 2013 | 11:14 AM
olsmokey's Avatar
its a 2095 rack plug. they were used on mack trucks that ran the p7100 injection hence the nick name "mack plug". it allows max fuel under max load. if you have a 215 pump with a 5 speed. they are pretty much useless because the rack is already allowed more travel. if not its an ok upgrade but there is some other adjustment that would need to be made to get the most out of it
Old May 20, 2013 | 11:17 AM
what else would have to be done
Old May 20, 2013 | 11:21 AM
olsmokey's Avatar
grinding down the barrel on your afc foot. and replacing the washers or griding down the washers on your afc diaphram
Old May 20, 2013 | 11:26 AM
and that has to be done if putting in mac plug
Old May 20, 2013 | 11:28 AM
the foot needs to be done to allow for the extra travel the plug allows for. The washers are to help clear up some smoke. You could also do away with the afc all together.
Old May 20, 2013 | 11:35 AM
how hard is it to grind the foot
Old May 20, 2013 | 11:44 AM
olsmokey's Avatar
its really not to hard. i would grind the barrel instead of the foot tho. take about .090 to .125 off the end of the barrel and your good to go.
Old May 20, 2013 | 11:53 AM
dump question but will i be able to notice a differents in power after doing all of this right
