Looked and cant find a related thread
Old May 6, 2013 | 07:53 PM
Th1rt3enneedles's Avatar
Default Looked and cant find a related thread
I've looked on this site and others and can't find a answer to my question. Keep in mind this is my first diesel, so this question maybe be dumb to some of you. ANYWAYS. When I start my truck up for the first time of the day the exhaust is unusually loud.(Truck is completely stock besides a lift). It over powers the sound of the engine. But as soon as I tap the brake it stops. I thought maybe it was because it was little cool outside and it helped the engine heat up, but today it was about 75-80 and it still did it... Is this normal or a problem?
Thanks Seth
And by "stops" I mean it goes back to a normal sounding exhaust.
Last edited by Th1rt3enneedles; May 6, 2013 at 07:53 PM. Reason: Automerged Doublepost
Old May 7, 2013 | 12:08 AM
CMCA Swartzkrautheim's Avatar
clean your exhaust backpressure tube i know someone on here had uploaded a video to youtube on how to do it just look it up on youtube you will find it, or try the search function for the site thatll prob pull it up too..
Old May 7, 2013 | 12:10 AM
Ok cool, I'll check it out. Appreciate it!
Old May 7, 2013 | 12:13 AM
yup, mine the supply wire on the alt actully worked its way out of the ring attaching it to the alt and was causing a voltage problem no fun in the dark halfway up north
Old May 7, 2013 | 12:22 AM
It's just weird cause it only does it the first time I start it for the day. I can let it sit for hours and hours after that and it won't do it. Just in the AM...
Old May 7, 2013 | 12:45 AM
joebob3093's Avatar
Moderator
if its only in the morning and doesn't do it any other time you are fine, no need to mess with anything. its the EBPV ( exhaust back pressure valve). it helps with warm up in the morning. if it starts doing it all the time or you cant get it to shut off you can either clean the tube or unplug it all together, it wont hurt a thing.
Old May 7, 2013 | 12:55 AM
Ok. Yeah my cousin thought that's what it was doing as well. I was just confused because its not cold out now. But anyways, should I let it turn off on its own or tap the brake after a few minutes?
Old May 7, 2013 | 01:12 AM
joebob3093's Avatar
Moderator
Let it run as long as you want. Its not going to hurt anything to shut it off
Old May 7, 2013 | 01:14 AM
Perfect. Hey thanks man
