fuel shutoff solenoid
Old May 4, 2013 | 02:38 PM
jw1975's Avatar
Default fuel shutoff solenoid
My fuel shutoff solenoid will not pull. It will however stay up if I pull it up by hand, it will also push by itself once key is off. I replaced solenoid and it does the same. Seems like electrical issue. Any ideas on where to start?
Old May 4, 2013 | 09:30 PM
daveO's Avatar
Check the relay, it should be on the firewall.
Old May 4, 2013 | 10:07 PM
1993firstgennewbie's Avatar
Yep I would try the relay also but there are 2 relays and they are on the driver side of the fire wall just above the valve covers
Old May 9, 2013 | 11:51 PM
senotext's Avatar
check the circuit between the starter solenoid and the pull circuit, it should pull when cranking
Old May 11, 2013 | 06:44 AM
jw1975's Avatar
After replacing the solenoid it still only works about 90% of the time. The times it won't start I have to push it up manually. Could it still be a relay problem?
Old May 11, 2013 | 07:45 AM
daveO's Avatar
Yeah, could be.
Old May 13, 2013 | 04:17 PM
If you buy junky **** from autozone or checkers ect ect or even napa it's a crap shoot if your parts are going to work especialy with electrical parts
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
