Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
remove old window tint?
Old May 1, 2013 | 09:02 PM
BigRed2500's Avatar
Default remove old window tint?
I want to get the tint on my windows re-done so i have to take off my old tint. Does anyone know how to proprely take it off??
Old May 1, 2013 | 09:13 PM
Ltk's Avatar
Ltk
they shouldnt charge extra for stripping the old tint. at least ameritint didnt charge me when i had mine re-done
Old May 1, 2013 | 09:31 PM
H.R.D's Avatar
Most places will charge you to remove old tint, at least that has been my experience. You should be able to use an ammonia based window cleaner and it should start to dissolve the tints bond to the window.
5 Ways to Remove Window Tint - wikiHow
Old May 19, 2013 | 12:36 PM
dodgeramit10's Avatar
yea, i just took off old tint from a window not long ago. i used Windex to soak it and then i got a razor blade scraper on it............ be careful though, you don't want to scratch your window!
Old Jul 10, 2013 | 12:33 PM
Drunkasschicken's Avatar
Easiest way is using a steamer. There fairly cheap at walmart or where ever, just a regular steamer for clothes... Take a razor blade peel a corner, start steaming the glass keeping tension on the corner. And it will start releasing. Leaves very little, to no adheasive. Then just alcohol, razor blade and a clean micro fiber and its prepped for new tint
and as they are saying above^^^ no amonia, or windex on the new tint when cleaning... thats where fade and discoloring kicks in. I use johnson baby soap and water, mix it in a squirt bottle. it will last for many of cleanings
Last edited by Drunkasschicken; Jul 10, 2013 at 12:33 PM. Reason: Automerged Doublepost
Old Jul 12, 2013 | 01:27 AM
carlod's Avatar
Using a steamer is the safest and best method. And to remove the excess glue, spray some WD40 and gently rub it using a fine steel wool.
Old Jul 12, 2013 | 06:46 AM
mysterync's Avatar
Side windows our old tint guy peeled, sprayed with windex and cleaned with a razor blade (5 minute process) rear windows and windshields soak with windex and put a black trash bag over the tint and let it set in the sun for 1hr. The tint will basically fall off. No risk damaging the heater grids. Don't use wd40 it will trash the felt strips.
Old Jul 12, 2013 | 10:04 PM
I my self have never heard of wd 40 either. X2 on the windex... some say the citrus is ok. Personally i only us the vinegar based, green label. Bust most of the time, Pure alcohol, it leaves no streaks and wont damage the new tint going on. Most the colored windex, has amonia in it. Tinting is like anything else. A good finished job all comes down to great prep work. I will take some pics tomorrow and post of my tint.
Old Jul 13, 2013 | 10:23 PM
removed old, alcohol and a razor to clean it, johnson baby soap and water to apply the new
Attached Thumbnails remove old window tint?-img_5315.jpg   remove old window tint?-img_5316.jpg   remove old window tint?-img_5317.jpg
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
Bluchewy
Mar 24, 2015 12:20 PM
