Cummins E brake or "Jacobs brake"
Old Apr 29, 2013 | 04:43 PM
1993firstgennewbie's Avatar
Default Cummins E brake or "Jacobs brake"
My dad has a 98 12v with a cummins e brake made by jacobs witch the part numbers are ( jacobs 022453) ( cummins 3933128) and it is not working, seems to be electrical. It has 2 inline fuses one for the main power just off the fuse box and one off the switch and whet the truck is off and you hit the switch it activates the relay but doesn't actuate the brake. but when you fire the truck up and hit the switch both 20a fuses blow. if anyone has any ideas it would be very helpful also if you have the same system and you have installation instructions or operating instructions I would love to see them.
this is a exhaust brake like a BD
Old Apr 30, 2013 | 09:05 AM
olsmokey's Avatar
sounds like a grounding problem to me. have you checked all your wires for chafe threw were it may be contacting a grounding surface?
Old Apr 30, 2013 | 07:51 PM
All of the grounds are good
Ill check the wires next time I'm there it look easy enough to pull the harness off since it all covered with weather guard
Last edited by 1993firstgennewbie; Apr 30, 2013 at 07:51 PM. Reason: Automerged Doublepost
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
