delivery valve question
Old Apr 27, 2013 | 09:00 PM
cummins Pride's Avatar
Default delivery valve question
i have 75hp marin injectors with stock delivery valves should i add bigger delivery valves with that big of injectors
marine
Last edited by cummins Pride; Apr 27, 2013 at 09:00 PM. Reason: Automerged Doublepost
Old Apr 27, 2013 | 10:03 PM
97cummins's Avatar
I think that would be a good idea. Have the del. valves match the injector size.
Old Apr 29, 2013 | 11:33 AM
ok thankss
Old May 1, 2013 | 12:02 PM
Seth'sCummins's Avatar
I am unsure what your stock DVs are, don't know what pump you have in your truck. I would say a set of 024 DVs should be a nice little upgrade if you want some more fuel.
Old May 1, 2013 | 12:34 PM
181s stock right now
Old May 1, 2013 | 03:10 PM
024 should be a nice upgrade from those. I have a set of 024s to install, just waiting on o-rings to come in...
Old May 2, 2013 | 11:14 AM
how much would they effect fuel milege
Old May 2, 2013 | 11:43 AM
They will have some affect on fuel mileage. This will depend on how heavy your foot is, the more fuel you put in your fuel mileage will change. In the nut shell you should still be close to the MPG you are at now.
If you only want a little more fueling then DVs are a great upgrade, but if you want to get a lot more fueling increasing injectors would be better and cleaner. This is because of how the DVs increase fueling. They increase the duration of fuel that is being injected, think of full/laser cuts and how they are hot and smokey all the time. As you can see if you just increase injector size it will not increase the duration of fuel but just increase the amount of fuel in the same duration as before.
I hope I am getting the point across and not jumbling everything together.
Old May 2, 2013 | 05:33 PM
you are i understand let me know the result once you get your 024 dvs in
RA113024
Mar 13, 2016 07:42 PM
oneloud59
May 16, 2015 10:00 AM
countryboy040993
13
Mar 5, 2015 08:58 PM
bonestock
Feb 1, 2015 08:41 PM
