Catalyzer full question
Old Apr 23, 2013 | 10:57 PM
jepledger's Avatar
Default Catalyzer full question
I was driving home this evening (loaded at 55-65mph) and the overhead comp gave the "Catalyzer Full Service Required" message, starting at 80% andgoing up to 90%. This concerns me as I have removed the DPF and the NOx filters after getting a couple codes as I didnt want them to clog (heard a pressure release when I unbolted the dpf). I have removed everything that could clog except the down pipe which I beleive has two catalytic converters in it.?. The truck has to work tomorrow so I need to know if I keep driving it will I cause damage if the cats are indeed clooging up?
Old Apr 24, 2013 | 04:14 AM
97cummins's Avatar
Did you get the proper programmer after you removed the dpf to fool the ecu in thinking the dpf is still there?If not,then thats probably why your getting the display saying it's full.At a certain point the ecu will put your motor into a derate mode because the ecu thinks the dpf is full.
And there is no cat convertors in the down pipe, just the doser
Old Apr 24, 2013 | 07:12 AM
jepledger's Avatar
Smarty jr me gets here tomorrow. The only reason the dpf is off so soon is it was clogging and not self cleaning (I dunno why). I knew the computer would have a hissy fit, but the dpf had to be removed, I didnt know it would be so militant about the subject. Do I need I replace the downpipe to make a dpf delete work? I notice most folks that have done the delete have a turbo back exhuast. I had planned on just making a straight pipe starting at the down pipe with a rear wheel terminus.
Old Apr 24, 2013 | 08:23 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
that message comes on sometimes. you can plug your smarty in and go to dtc read. you prob wont have any codes but clear dtc codes anyway. this should take the overhead off. if it doesnt give me a call. maybe i can help
Old Apr 24, 2013 | 09:00 PM
jepledger's Avatar
After about 15 miles this morning the cat full message went away, I don't think the truck derated the power. I have to say this truck sounds amazing with not exhaust the thing sounds like an old peterbilt with the sexiest sounding vaccum ever strapped to the engine, that alone is worth the cost of a tunner.
Old Apr 30, 2013 | 05:13 AM
97cummins's Avatar
Nope,you don't have to remove the down pipe,it can stay on.
Old Apr 30, 2013 | 08:56 AM
jepledger's Avatar
Thanks for the advice my smarty came in. So the dpf and egr fell off a couple days ago. Everything is running good so far.
Sep 24, 2015 08:50 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
mrweasel
Oct 25, 2014 05:47 AM
