fuel pressure
Old Apr 22, 2013 | 06:46 AM
eddie7644's Avatar
Default fuel pressure
I have a 96 12v and I just installed a fuel pressure gauge. What is it supposed to be reading I'm getting 45-48 psi at idle and under load the lowest it dropped was about 22-25 psi. I also have a stock lift pump. Is this right??
Old Apr 22, 2013 | 11:21 AM
94 12valve's Avatar
That sounds pretty high for a stock lift pump ... with a stock overflow your suposed to see a max of 25-30 at 2500rpm at a free rev. if the pressure you say you have is right I would leave it alone nothing wrong with running that much fuel press assuming there is still fuel returning to the tank.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
