no fuel from pump
Old Apr 21, 2013 | 07:38 PM
danny_1042's Avatar
Default no fuel from pump
i just install 191 delivery valves. now i cant get any fuel through them. if i loosen them up it will pump fuel through them but if i torque them they wont pump nothing. any help needed.
Old Apr 22, 2013 | 02:50 AM
97cummins's Avatar
Sounds like something is being blocked when the del. valves are torqued down.
Old Apr 22, 2013 | 07:53 AM
93_Fummins's Avatar
What do you mean, you "aren't getting any fuel throgh them"? Are you cranking the motor or simply priming with an electric pump?
Old Apr 22, 2013 | 11:23 AM
94 12valve's Avatar
after a DV install you need to rebleed the injector lines to get the air out of the system. crack a few at the injector and crank the motor till you see fuel shoot out
Old Apr 23, 2013 | 02:28 PM
danny_1042's Avatar
i have bled air , i've removed the fuel heater thinking it might be the leak, but i still can't get fuel out of the pump . and if i loosen up the delivery valve fuel begins running out. i've put new fuel shut off, still no luck. fuel is getting to pump but not enough to push through delivery valve.please help. i miss my truck.
i am priming then cranking with motor.
Old Apr 23, 2013 | 02:42 PM
turbo2332's Avatar
dumb idea... did you install them upside down? just a passing thought a dumb one but a thought
Old Apr 23, 2013 | 08:18 PM
danny_1042's Avatar
LOL! didn't install upside down? i even double checked myself. I'm going to put a pressure relief valve in the return side to see if that helps
Old Apr 27, 2013 | 03:30 PM
danny_1042's Avatar
i have figured out that the rail in the pump is not moving. it is stuck. trying to figure out what is causing it?
Old Apr 28, 2013 | 02:40 PM
94 12valve's Avatar
pull the shutdown solenoid up when checking this, with the key off the rack should not move. turn the key on and pull it up than check the rack
Old Apr 28, 2013 | 07:34 PM
danny_1042's Avatar
i have tried with the fuel on and off. i can move it just a little back and fourth but is binding in some way.
